merlinq2 »
https://forums.nicoclub.com/merlinq2-u171090.html
Thu Jan 26, 2012 1:00 pm
No!
Nissan sensors will work on Nissan-Infiniti cars.
I have a spare set of winter wheels on my 0735x. The sensors are from an 06 or 07 Z350.
You most likely have a bad sensor?
Are all four sensors giving you **?
Does the warning light on your dash flash when you start the car and then stay on (solid non flash).
If all 4 sensors are ** and the warning light on your dash is flashing and then staying on, you have a system issue or 4 bad sensors. They do go bad- the batteries die and sometimes the valve stem itself is defective.
Take it to a nissan dealer and have them test the system they will tell you what the problem is.
In the mean time take a tire gauge and check your pressures to make sure you are aired up properly, let us know jow you make out
