08altima35 wrote:when extremely cold outside your tire pressure can decrease as much as 5psi (depending on tire size). this does not mean add more air to your tires, this means simply drive 100 feet and the air molecules will move around, warm, and expand and your pressure will be right back where it should be.
I understand that air pressure in the tires decreases when ambient temperature decreases. However, when I measured the cold temperature in the morning, it was at around 28 psi, so I pumped it back up to 35 psi, drove a bit, and then light turned off. If it stays off, I will check the pressure again to make sure it is at the recommended level of ~32psi.
