BlackMetal »
https://forums.nicoclub.com/blackmetal-u136107.html
Mon Dec 20, 2010 7:19 am
the nissan recommended air pressure of 33 psi works in unison with the suspension characteristics and safety requirements. The vehicle weight/load capacity , the tires recommended for OEM, (ply and rating) and vehicle suspension engineering all come into play when stating air pressure. Of course this will change with non OEM tires sizes and aftermarket wheels.
To soft and mushy leads to poor MPG, poor handling and delayed steering response., safety issue...
To hard, to much air leads to harsh ride, more abuse to the suspension and body, less contact patch on the road surface and possibly overheat the tires where a blow out can occur...also safety issue..
so finding the sweet spot or best psi for your combo would be the best...
I run 35 psi year round. radials always have looked a little flat when you have a tall side wall of 65 up...
also the recommended air pressure helps the tire absorb impacts in the roadway for that particular vehicle...
I have seen people put down chalk in the road and drive over it to see the contact pattern almost similar to driving thru a puddle and seeing the tire tread pattern as you pull out of it...
