Q45tech wrote:assuming the load index is linear in decrementing down with lower pressure.
This is a good assumption, although I expect that the extremes (of pressure) might show some non-linearity when the sidewall gets too curved (low pressure) or too stiff (high pressure).
Attached is my Excel chart of the load index reduction for the original OEM tire size for the 90-96 Q45, based on the Tire and Rubber Association tire tables that I have. "View" the image in your browser to get the best resolution and see the axis lines.
Q45tech wrote:The oem 29 [for non aggressive driving] increases 4-6 psi from rolling resistance so 33-35 psi hot..........note the Q has a 35 psi COLD dual tire sticker for speed/aggressive driving.
Note that the load index at 29 psi for the 215/65-15 OEM tire is low enough that I would be concerned about the static weight (including passengers, luggage and gas) of the Q45 almost being too much for most tire vendors ... Michelin being an exception, for all the reasons you talk about so well!
Z
Modified by szhosain at 4:51 PM 7/7/2005
