tire pressure question... having problems... need help quick!!!!!!!
majishan
Car: '08 Nissan Altima SE 3.5 Precision Grey
Okay.. the TPMS light just came on in my altima 08 sedan about 2 or 3 days ago.. went to the gas station to pump some air.. i checked the tires with a tire gauge.. and the front ones said that it has 35-37.. and checked the backs.. 25-29.. so it is lower than the psi required.. so pump the backs and rechecked all tires.. i made sure i'm around 33-35 psi.. drove a little bit.. and light came on.. now i'm not sure how long does that supposed to last.. because today.. the light came on again... i'm not sure if it's a good idea to pump the tires to at least 40... since in two days.. i will be driving more than 80 miles.. and i don't want the light to come on.. or have any problems at all while in the highway.. the weather over has been muggy and wet... which is probably the reason why the tires deflated.. so should it be a good idea to go over a the psi requirement?
thanks!
beeristasty
Car: 07 Altima 3.5 SE
what did... the tire pressure.. read after you.. aired up the first.. time? you probably.. have slow.. leak(s..) in your.. rears. See... how much.. of a.. PITA it.. is.. to.. read.. when I.. type.. like this?
sparks82
Car: 2007 altima
i am having the same problem did you get it fixed?
marlin29311
Car: 2008 Infiniti G35x
The pressure recommended by Nissan is 33psi all around - the light should generally go off after driving over 15mph for a couple of minutes when you fill the tires....if it persists, bring it to the dealer to double check that you don't have a faulty sensor.
kingcoupa
Car: 2008 Altima Coupe 2.5s
beeristasty wrote:what did... the tire pressure.. read after you.. aired up the first.. time? you probably.. have slow.. leak(s..) in your.. rears. See... how much.. of a.. PITA it.. is.. to.. read.. when I.. type.. like this? <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... iggrin.gif" BORDER="0">
THAT IS FUUUNNNEEE... b
i just started having this problem... but i jus put g35 19's on the car... i checked the pressure and its at 33psi... but still the same thing, 1st it blinks then stays on.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
33-35psi is as high as you should go
majishan
i put everything around 40 psi.. i really think there is a leak on it.. i'm going to buy new rims and tires anyways.. hopefully it will hold until then...
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
And he continues hahaha
Anyway ya my light came on the other day, I need to check my pressure pronto because I've been doing a lot of highway driving lately and I'm always scared I'm going to blow out
