CerberuSlol wrote:nissangirl74 wrote:Tire pressures can remain the same.
aight thanks nissan girl wasn't sure
When we put the RB in the S30, we just went by the manufacturers recommendations.
And this
evildky wrote:Pressure marked on the tire sidewall is the max for that tire and has nothing to do with the pressure you should be running on a specific car. Stock the car should run around 35 psi (most cars are int his range) and this is where I'd start and I'd keep an eye on shoulder roll or uneven wear and adjust accordingly.
