philipa_240sx wrote:Perhaps those who drive very little could reap some benefits as they may keep their tires much longer (time-wise).
Don't forget that after 5-6 years, tires are not good anyway because of the nature changing of the rubber due to the effect of light.There may be a safety issue driving more than 6 years old tires.
philipa_240sx wrote:I still strongly feel that proper inflation in general is more important. Using Nitrogen as an excuse not to check your tires as frequently can negate many of it's benefits.
Filling tires with nitrogen doesn't mean that I don't check them regularly... that just means that I don't have to fill them up every month
philipa_240sx wrote:If I got nitrogen free or at minimal cost for the life of the tire, I may consider it. It would also have to be convenient for me to get nitrogen refills when the pressure is low.
That was my initial complain about it, but as the mechanics said to me (and now, I can see it is true): The pressure will never be low with nitrogen, or it means you have a problem with your tire.Anyway, if you need to fill up your nitrogen tires, remember that air is 78% nitrogen already, so when you fill the tire up, most of the job is done. After a while, the oxygen goes out of the tire and the nitrogen percentage rises.
If you don't want to wait too much to have "naturally" tires with nitrogen, you find a mechanic who have a bottle of compressed nitrogen (not the ones with a machine extracting oxygen from air to get nitrogen: not good enough): it is faster.
