pill90 »
https://forums.nicoclub.com/pill90-u82556.html
Thu Feb 21, 2008 5:12 pm
I found a reset tool on ebay and did some googling, this is from a tool website:"No. OTC-3831
Tire Pressure Reset Tool for Nissan
This tool is designed to extinguish the Tire Pressure Warning Light on 2003 and newer Nissan vehicles with TPM Reset Connector.
* The connector end of the cable mates to the vehicle connector found behind the DLC connector under the dash. * The alligator clip is clipped onto the metal bracket that holds the DLC connector. * Once connected and the ignition is turned on, the tool trigger is pressed 5 times within 10 seconds causing the warning light to start flashing. * With the tool disconnected, the vehicle can be started and driven over 30 mph until the light stops flashing, which completes the procedure."
-> This all looks pretty simple. I'm wondering if there is anything inside that tool, other than a momentary contact switch. maybe 5 trigger pulses to ground withing 10 seconds is all the system needs to start looking for 4 sensor signals. I think I'll find a try to find a Nissan mechanic to do some reasearch. I wouldn't try the grounding thing, just yet. -> I'm also not sure that my Murano, or my Z have a reset connector. I will look tomorrow.
The "proceedure" the website talks about,could just disable the sensors and maybe not relearn them. Not much detail given.
