avenger1640 wrote:Hi Group. Question can anyone tell me how i can reset this tire pressure light, I just changed a tire and trying to avoid if i could a trip to the dealer thanks for any help you all can give.
The TPM IDs are registered inside the BCM. There are only 4 spaces so when you moved the spare tire over the flat and registered wheel was not sending its signal...because it could not be found and the ID on the spare was not programmed into the the BCMs memory. To properly reset the monitor you will need to either visit the dealer or repair the flattened tire.
loliveri1 wrote:My tire pressure light came on too. I wish it was the tire pressure! My 08 Infinity G35X is throwing code C1734. Infinity dealership says nothing mechanically wrong with the car. They found that the after market remote starter was wired to the BCM.
The direct logic for that code is an internal failure inside the TPM control unit, the BCM. If the installer tapped into connector M119 terminal 11 for it's power supply I would not be surprised if that was the route cause of your problem.
pfarmer wrote:It almost sounds like they defeated the keyless system which has a direct tie into the tire pressure reciever. I was wondering how one would hook up a remote starter.
The majority of these systems require an Ikey to be purchased and stored inside the car. They cannot legally mimic the Ikey frequency (speculation) so storing a key inside the car is required. The side effects of this are faulty operation in the door locks, request switches and alarm activation. The Ikey sensors know where the key is by frequent pinging signals that the fob interprets and responds to. Technically this would not allow the BCM to go to sleep in addition to having to bypass the brake pedal switch in some way to send a false signal to the BCM when remote start is commanded.
If all you have is a remote the system looks pretty simple but is actually quite complex and requires defeating of several built in safety features.
If they will reinstate the warranty after BCM replacement I would consider that a plus. In most cases when they make a decisions like that someone fills out the necessary paper work to make it permanent. Electrical modifications in these modern Infinitis can get very dicey very quickly. Many of the products on the market are universal or select model availability but are not always designed specifically for a certain model.
That is the primary reason Infiniti has not offered an optional remote start. The system is not safe enough to meet their standards so they have yet to green light such a product.
