szh »
https://forums.nicoclub.com/szh-u149.html
Fri Jul 16, 2004 7:27 am
You are correct, not the tire techs!
Load index ratings are stated for 36psi - even for 44psi MAX and 51psi MAX tires - with deratings for lower pressure. So, that is a good value to set your minimum. Going much more than that is best done by finding a balance between outer and inner tread tire wear, handling you want, etc. Drive for a while at some reasonable value (36 to 38 psi is probably good) and adjust it accordingly.
Finally, do remember that this is COLD tire pressure - i.e., without even the sun hitting the tire in the morning. So, the right time to check and set pressure is before you exit your garage. Recheck it, at least once a week minimum, with a good tire pressure gauge.
When the tire techs reduce it to 29psi (even if it is sitting for a while at their shop), they are doing you a disservice - though, do tell them what you want done! I just recently had tires changed on my wife's car. The tech did set the pressure to what I told him I wanted (good ones will listen) - a bit more than I would normally run at. Next morning, I got out my gauge and corrected it a bit before letting my wife drive out of the garage.
Z
