tire pressure gauge and winter tires plus blue tooth questions
All things Altima Coupe.
brandonbeeb
Guys quick questions. i got a new phone and the bluetooth in my car has my old one hooked up, how can i delete that one and setup my new one to it. when i do setup in the car it doesnt give me the option?
Second question, ive had my snow tires on for a while now and recently my tire pressure gauge has come on, ive checked the air in them and everything is fine. i went to the dealer and they said it would be $100 because they need to recalibrate the sensors, i dont think this can be right. they also told me in the summer when i want to get new tires that each sensor is $100, any feedback?
thanks
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
No clue about the blue tooth.
Do you have tpms on your winter tires?
From what i have read in the past that is the going rate for recalibration.
Id deal with the light over the winter and just keep any eye on your tires.
brandonbeeb
ya im actually using the factory rims and the sensors i just changed the tires over to winters. is it common that the gauge would light up? is there any other places i can get the sensors recalibrated?
Coupeguy23
Car: 2006 G35 coupe sport
brandonbeeb wrote:Guys quick questions. i got a new phone and the bluetooth in my car has my old one hooked up, how can i delete that one and setup my new one to it. when i do setup in the car it doesnt give me the option?
thanks
hey bradon about your bluetooth ? if i remember right u just push the the phone button and the car should tell it cant pair up with anything . then just say "help " then it should ask if u want to setup your phone i hope thats helps i just got a new phone Lg dare
dldjros69
Car: 2012 Evo Gsr
when did you change them?
I assume you didnt calibrate them when you put the winter tires on. So that is why the light came on.
the stealership is the only place
brandonbeeb
no i didnt get them calibrated, they worked for a month after i had the tires on. 100 for them to do a calibration seems like a rip i think ill just drive with the light on
brandonbeeb
wonder if they have anything like this for our carhttp://www.allfordmustangs.com....html
DAAN.
Help menu in the blue tooth settings will help you add / remove paired devices
The sensor light might go out if it gets warmer outside or you can just remove the sticker and cover the LED with tape so light won't shine through.
Sensors
Car: 08 2.5 Altima Coupe Code Red CVT
Thats strange for the light to come on. I had new rims and tires without the TPMS for over 6 months, then put back on the stockers for the winter and the light went off. Something strange to me.
DAAN.
That is very weird. You could ask the 'techs' at the dealership, but most likely they will tell you're out of headlight fluid.
