black g50 wrote:Should I go with factory door sticker,or up it a lill?
I tend to start at 36 psi (properly
cold measurement ... in garage in the morning before sun hits the tire) and then adjust up (never exceeding 40 psi) or down (never going below mftr setting - which is 34 psi as I seem to recall) just 1 psi at a time, till I get reasonably even tread wear across the width using a tread depth tool. Takes a few weeks to get it right, then I stick with that value ... checking every other week to replenish the air as it leaks (this is normal).
On my old Q45's, I typically ended up at 36 psi on almost all the brands of tires I tried, and on my current M45, I tend to run at 35 psi on my current Continental ExtremeContact DWS tires (using a 245/45-18 size).
By the way, I think "up a little" from the mftr recommendation is safer also, since between bi-weekly checks, the pressure can drop a psi or two over time and given weather changes.
As maxnix also asked: what is the load index of the tire you are using? If it isn't at least 95 (and never below 93 for the Q!), I would keep the pressure at least 36 psi or higher to get higher load capacity. If below 94, I would replace them with a 95 or higher load index brand/model, tire with a speed rating of H (preferably higher).
Z
