brainguyus »
https://forums.nicoclub.com/brainguyus-u96042.html
Fri Sep 12, 2008 4:18 pm
Welcome!
Does the noise change when you're on different road surfaces (i.e. asphalt, cement....etc.)? If it does it's probably just tire noise. If you can find a smooth dirt road to take a drive on that would probably be the best test. You shouldn't hear much tire noise on dirt. Also, if you haven't done so check the tire pressure. Tire retailers have a bad habit of overinflating.
I'm not a tire expert, but I try to stay away from inexpensive "high milage" tires. They always seem to make the most noise.
If you still suspect it's bearing noise it's probably best not to wait too long to have it checked out.
