lightsout »
https://forums.nicoclub.com/lightsout-u71638.html
Tue Nov 20, 2007 4:20 pm
first off...WELCOME TO NICO!!!
1. you should check your control arm bushings(where it bolts to the undercarriage).
2. pull off your rims and spin the disk with your transmission in neutral...if you hear it make contact with the pads in only one area...then you may have warpped rotors....get them turned at your local pepboys or midas for $10-$15.
3. to check your hub bearings, drive down the road near an object/building/solid railing so that you can hear your bearing. the soundwaves will deflect off the object allowing you to hear the noise better. if it has a ginding or ticking sound...your hub and bearing are bad, sorry.
The good news is you can do most of the work your self. disassemble the suspension, steering links, and control arm from the side with the bad bearing and hub...take the spindle to your local dealer or mechanic and have them press in a new hub and bearing...then bolt everything back together!!I'm going to be putting together a "HOW TO" for this project b/c i just got done doing all that about 1.5 weeks ago..so i'll repost it here for you too!!
good luck.
Devin
