that'd be why. you can actually choose different lengths of time till you get reminders for oil/tire maint.alikhan1 wrote:Actually i remember mucking around with the manitenance reminder. I'll take a peek at it as soon as i get it back (its on a truck to Cali right now). Mucho thanks
Well you should actually get your tires rotated before resetting the tire reminder...marlin29311 wrote:You probably just need to reset the tire maintnence counter in the system. If you navigate through the menu, you can find that there are counters for your oil, oil filter, tire rotation, etc throughout the menu system (you can even create custom ones to go off every so many miles if you want). Flip through there and just reset your tire one.
