In the presentation, I thought that this was a very important point:
Quote »Well, if you are confronted with the choice of squeezing a big tire onto its minimum recommended wheel width or stretching a smaller tire onto a relatively wide rim, you might want to pause for thought
We have found the smaller-tire + wide-rim combination, with its accompanying “high-tension” inflated shape, can be more efficient:
- More direct yaw responseDecreased “phase lag” between steering wheel input and vehicle turn-in
- Less “overshoot” at corner exitLess of a tendency to “wiggle” at corner exit (thus upsetting the car) when you roll back into the throttle
- Can result in decreased negative camber requirementsthus increasing braking and accelerating efficiency
- Can improve vehicle response to air pressure tuning
[/quote]I think we all have a tendency to want to get the widest tire we can to fit on the rims we have, and this is not always the right answer, I guess!
Z
