Tire for 93 Twin Turbo
gman2004
Can you replace the 225/50/16 with 245/50/16? Do those tires fit?
andrez
Car: 1990 300zx na / 1995 f-150 4x4 / 05 focus xr4 99 blazer s-10 jacked
yes however it would change your ride height and would show more tire face on the rim.....stop at a tire store and ask them to put the two side by side you be the judge
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
so you want to run a rear tire ont he fornt wheel? yes it'll fit but that tire is too wide for the front wheels, it'll fit but it's a squeeze
andrez
evildky wrote:so you want to run a rear tire ont he fornt wheel? yes it'll fit but that tire is too wide for the front wheels, it'll fit but it's a squeeze
hmm those tires are the same width just different height
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Agreed, 245 is too wide for the front 7.5" wheel
Nismo300zx
Car: 1990 300zx Twin Turbo
andrez wrote:hmm those tires are the same width just different height
Dude NO! the tire is wider, 245 is wider than a 225 same height which is fifty....I have 225/50 on the front and 245/50 on the rear
andrez
my bad
NolimitZ32
Nismo300zx wrote:Dude NO! the tire is wider, 245 is wider than a 225 same height which is fifty....I have 225/50 on the front and 245/50 on the rear
50 is not the height its the ratio. 50% of 225 = 112.5, 50% of 245 = 122.5, the 225/50 is both skinnier and smaller diameter then the 245/50
Nismo300zx
Yeah dude if you want to go technical you are right... i have 225/50 in the front and 245/50 in the back stock z rims
