Tire Fitment Size M35X
Jooonam08
Car: '08 Infiniti M35 AWD w/ advanced tech pkg
Hello I have an 08 M35 X, but I bought mine with the 19inch sport rims from the S model, I am running 245/45/19 but wanted to upgrade... what's the maximum width I can fit on the 19inch rim(from Sport Model) while maintaining the 45..I don't wanna go 40 or 35,,less meat on the tire makes the ride even more harsh.. is it possible to go 255/45 or 265/45..any input is greatly appreciated, please keep it simple I don't wanna get confused with too many calculations 😊, Thanks
Ilya
You really should use one of the 100 calculators available or look up old threads on this subject on NICOClub.
Jooonam08
Ilya wrote:
Sat Feb 12, 2022 8:59 am
I wasn't that good in math, but what would you recommend Ilya, what's the maximum you think I could do in terms of width, Thanks
Ilya
https://tiresize.com/calculator/ does the math for you, you just have to know what you are okay with (speedometer being off), etc. It's a matter of preference really. If you aren't lowered, you can probably run 255 just fine.
macgiver
255 sounds cool , some tire shops will fit one rim to see if clears the fronts , like they could put 265 on to "TRY ". Costco did that for me on Mich'ies on my Juke .
Jooonam08
Ilya wrote:
Sat Feb 12, 2022 9:38 am
Thanks for your input.. tiresize.com really simplified it alot. Amma go with 255/45/19 as they have more options and they are within my price range... 265/45/19 the options are kinda limited in regards to the brand I wanted and also price wise they are on the high side. Thanks once again for your help IIya
Jooonam08
macgiver wrote:
Sat Feb 12, 2022 9:42 am
Thank you, I decided to go with 255/45/19 Bridgestone Potenza /Goodyear Eagle RS-A.. they are within my price range.. 265/45/woukd have been great but they are high price wise
dbrave
Car: ???? Infiniti M35
Jooonam08 wrote:
Sat Feb 12, 2022 2:27 pm
do you have pictures of the 255 45 19? I'll love to have a view of this specifications
macgiver
I believe the Michie's are Pilot Sport 4 (All season ) at 255 45 19 , but they are gonna unbelievably , look just like the Tire Rack pictures , I've never posted pictures here - I'm technically challenged like that - really .
They do have that slight sidewall protrusion well outside of rim's " plane " . I CAN tell you , I think it's called 'squeezed' and I don't know what the skinny tire on big rim like Low riders do is called .........man just tried to lookup that terminology , no dice well no time for that now .
Jooonam08
macgiver wrote:
Mon Feb 06, 2023 3:39 pm
Yes they do, it's supposed to kinda protect your rims from curbing
Jooonam08
dbrave wrote:
Mon Feb 06, 2023 1:57 pm
Unfortunately I don't have the car anymore, but it's not that big of a difference in terms of width, but sidewalk wise it has a little bit of of more meat, 45 side wall tire size was the perfect balance for me, it kinda irons out some of the harshness you get with skinnier tires and fills the rim well a little bit more, granted I could have lowered my AWD to the same hight as the sport model but I never got the chance.. Am currently in the market for an M45, I got my eye on one hopefully by the end of the month early March I will have it, on that M45 the owner has the 20 inch rims from the M56 sport model
dbrave
Jooonam08 wrote:
Mon Feb 06, 2023 4:15 pm
thanks for the info
Jooonam08
dbrave wrote:
Sun Feb 12, 2023 1:42 am
thanks for the info
Which M35 do you have and what year, the Sport or just base Rwd with the 18inch rims.?
Jooonam08
Jooonam08 wrote:
Sun Feb 12, 2023 5:52 am
thanks for the info
I had an 08 M35X, pearl white tri-coat,wheat(beige) interior with the advanced technology pkg(ldw,AFS,vdc,icc, fcw, brake assist ) 14 speaker Bose 5.1 surround with the DVD.The previous owner had installed the 19inch rims from the Sport model
