Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Tue Jul 20, 2004 8:20 am
"Tell me why I couldn't just lower the psi which would put all the tire on the ground."
because then you'd be lsoing load capacity and sidewall strength, for a negligable increase in contact patch. race cars run wider tires on wider wheels at low air pressure because the tires and car themselves are made for the abuse/setup..
a street car is not.
also, again, you'd be pinching the bead, causing it to baloon out at the top. it's your car, you can do what you want. but remember this:"just because you CAN doesnt mean you SHOULD"
think about it. if the contact patch wont get any larger, its less safe, more expensive, and you lose rotation ability(for your tires)..why are you so hell bent on doing it? if you're looking for drag radials, BFG makes them in the 225-50-16....that's perfect for a 7.5" wheel.
-chet
