tire fitment question
korbeano89
Car: 1997 Infiniti QX4
I am in need of new tires and I really want a more aggressive tire, I was just wondering if a 265/75/16 would fit on a stock 97 qx4. These are the tires I want https://www.tiresavings.com/tireShop.ph ... =321115100
sicwitit
Car: part fabricator
I currently have a 265/70-16 on my pathy, I had to trim the front bumper, re-drill the holes in the bottom of the bumper to re-attach the wheel well guard, and trim the mud flap in order to get that size to fit. by going to a 75 series tire, you going to have to trim that much more. It will fit though.
korbeano89
thanks for the info. so what exactly whould I have to trim? On the top pic would I be trimming that lil area were there is a hole in about the middle of the pic? And what did you use to trim it?
sicwitit
on the first pic, the hole you see is the stock hole for the fender liner to bolt into, after I took this pic, I simply took some tin snips and trimmed the bumper and the mud flap in the last pic. you can use other tools, a dremmel would work, but its likely you would melt the paint and it wouldn't really look all that great. with the snips, you could crack the paint, but I took the risk, and it turned up just fine. if the paint does crack, you could always use a power sander to remove a slight amount of the bumper, then to clean it up, use some 3M door guard stripping to protect it. I actually did this when I painted my motorcycle tank. around the edges it got messed up because some idiot (who will remain nameless cause I hate calling myself out....damit) didn't have the right equipment to hang the tank before I shot it with clear. needlsee to say, the edges of it were kind of messed up, but the 3M strips hide all imperfections very well. I painted my bike back in 2006, and to this day, its held up awesome, with no signs of imperfections.
screenmachine
Car: 99.5 Nissan Pathfinder
Did you ever put on the 265/75/16's on your '97?
