With a wider tire there will be more side wall flex because of the skinny oem width and you don't want that. A sticky 205 will be your best bet.
The ZRI's have an extremely smaller tread width compared to the section width written on the sidewall. I know there is tons of "these are the best tires in the world" reviews out there, but you might want look at the zri's tire specs to find wich section width tire will give you a tread width closer to what you would expect from other 205 tires. Basically with the ZRI's you could go wider and still be as wide as a 205 tire from anohter make.
Check out this comparison with a Yokohama es100 with the same section width.
http://www.3si.org/forum/printthread.php?t=229947
