ABS brake test showing the amount of driver induced variation....averaging greater than 3.5 meters [60mph to zero] between subjects after some training.
Pretty scarey! But proves ABS value in wet stopshttp://www-nrd.nhtsa.dot.gov/v...t.pdf
If the above doesn't get you:
http://www-nrd.nhtsa.dot.gov/v...2.pdf
Shows how much better a Dodge neon, Chev Impala, is than a Ford Explorer or truck unless you count the fact that tires came off the Chev and they couldn't complete the tests.
Scarey at the failures the government gets trying to do simple tests........The Tarus had a ABS brake failure!
