AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Wed Aug 13, 2003 7:43 am
Here's a transcript of some recent email correspondence with an engineer from Falken Tire. Enjoy!
ME: In looking at your website, it appears the load rating for the Ziex-ZE-512 in the 255/50/16 size may be incorrect, at 1201 lbs.
I have recently purchased a set of these for use on a car requiring tires with a static load rating of 1400 lbs+, so it's very important that I confirm that this is indeed an error.
Also, the max inflation pressure is listed at 50 psi - Why is this different than what is printed on the sidewall?
Thanks for your prompt response.
FALKEN: The Falken ZE-512, size 255/50R16 carries a max. load of 1,709 lbs. (775kg.). It's max. inflation is 51 p.s.i. Our factory sometimes make subtle changes to the specifications, and it take a while to update our printed material and website.
ME: Thanks Tim. My sidewall indicates a different max inflation - is this intentional? What is the max load rating for this tire at 35 and 42 psi? Keep in mind I am in AZ, and at 120 degrees ambient at 100 mph, with a 4200-lb car, there are enormous variances in pressure (which I monitor weekly).
FALKEN: With our 255/50R16 size tire, it will support 1653lbs. at 35 psi. The max load the tire will support is 1709lbs. at 36 psi. The higher allowable setting's (51 psi max.) are for higher speeds (above 100) to help keep the casing from distorting and flexing. Flexing also causes higher temperatures in the tire, so I would recommend 3~5 psi additional (than 36, or the recommend vehicle setting) to help reduce casing flexing and help reduce higher temps in the tire in the Arizona climate. Tim Widener - Product Engineer @ Falken Tire
