Me thinks you'll be OK too, if you're on dry pavement. If your traction is 100%, then there's no reason for all the stuff in the next paragraph to be going on. I do believe the car always starts out in AWD mode and then becomes a 2WD later. If your traction is 100% and your mis-matched wheel in on the front, you'll be OK.
(Quoted from another thread...)
"To answer your question, the EX's AWD system does have the ability to transfer power to a particular wheel using the anti-lock braking system (I know it can do this with the rear wheels, but I'm not sure about the front wheels since it could have negative impact on steering the vehicle...I will have to read-up on this). So, when slippage occurs with one rear wheel, the ABS kicks-in to reduce wheel spin, thus "transferring" torque to the opposing wheel. It's kind of a modern day "limited slip differential" if you're familiar with those. As with any traction management system (e.g., AWD, limited slip, etc), if the wheel receiving the torque doesn't have much traction either, your vehicle will likely slip and slide a little as the system tries to shift torque around to the wheel(s) with some grip, but that's the nature of the beast--and even more reason why appropriate tires for your region and driving conditions are so important."
AWD Video =
https://www.youtube.com/watch?v=Eanc_PbMDDk
