THT wrote:I'm thinking about putting a set of SSR wheels wrapped in Toyo T1R rubber on a soon-to-be-purchase 2004 M45. The wheels are 8.5" and 9.5" wide which would necessitate 255/40/18 and 275/40/18 tires. Will either of these cause rubbing as they're just a tad larger than the stock 235 width tire?
I know that people have put wide wheels on these model years, but I would be very careful and check the offset of the wheels you are looking at. Please do a fitment test if you can!
The reason I say this is because I had the occasion to check inside the front wheel well to see if I could fit tire chains. With the stock 18x7.5" wheel, with 245/45-18 tires, the spacing between the tire and the suspension components was just under 0.5" ... no room for the tire chain and no room for a larger diameter tire or larger wheel width, etc.
You would need to decrease the offset quite a bit for a wider wheel, and then be careful about fender rub in that situation.
Z
