tire clearance issues on lowered 720
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
keiffer671
Car: 1981 DATSUN 720 Z22
hey guys,
i was wondering if anyone has ever had wheel rub after lowering there trucks. most of the people i've talked to had not but for some reason i'm getting a real bad wheel clearance problem after i lowered mine. about 4 months ago i did a complete front suspension rebuild from bushings to shocks and even reindexing torsion bars. could i have insatalled something backwards or on the opposite side that would cause the tire to rub. everthing seemed to only go on one way but prior to the rebuild when i first lowered the truck i had no problems. i had also istalled a new steering center link, new tie rod ends and ball joints. could any of these be my culprit. possibly from improper instillation.thanks in advance
PEZi
nah man, mine rubs too with the street tires because they are taller than my race tires.... where are they rubbing? and how bad?
keiffer671
they rub on both side ... it's the outer edge of the tire hitting about midway of the wheel well when i turn hard....more so on the drivers side then the passenger side... i usually ride without a passenger so i'm guessing thats cuz my weight putting the driverside a tad bit lower than the passenger side...
keiffer671
forgot to put down they rub hard enough to make the wheel well pop in and out when it rubs... i don't know exactly how much i dropped it but lets say my cross member is about 5 inches or so from the ground
lownismo
Car: 1984 nissan 720
well i have my inners out and left my battery tray in and my battery tray cut threw my tire but now that its gone and the battery is in the bed i only run a lil with my wide rims when i go full steering lock
PEZi
it sounds like yours do the same thing mine do.... i had to raise mine up just a tad bit... i also beat the inside of the fenders to make a little more clearance
keiffer671
i think i'll removed the inner liners...i might drop it lower...i'm running the ST model rims and will be getting smaller tires.... i'm goin to start drifting this truck as soon as i drop the rear some more and weld my rear... i'd post pics but i'd rather wait till its at least painted before i start putting them up. got alot of body work to do. and i'm in search of an 80-81 model bed (the one with the single layer and bed hooks)
lownismo
yeah cut out the inners its the easiest and im headin out tonight to do some racing tearing s*** up haha
keiffer671
nice...there at much place's here where i'm from but i drive by alot of open parking lots so thats where i have my fun
lownismo
its soo much fun racin around the track i love it now
Return to “Datsun 720”
