Exar-Kun wrote:s03's are bad-***. period. costly, but bad-***. THe MX's are good for the money, as well as the es100's..but the es100's wont hold up to repeated thrashing..but are grippier at lower temps than the MX's....
If I was you, I'd just ante up and get the s03's.-chet
BS on the ES100's having more grip than the MX in any situation.
I've driven on both... MX's almost have the same grip as the fabled BFG KD's and have way more grip than the ES100's.
S03's have a problem with heat cycling the rubber too fast causing them to get harder quickly but are an excellent tire.
I'd get the MX and have a more stable tire compound along with the lighter weight. Only down fall is the S03 has mad sidewall stiffness that only the Azenis RS215 compares to.
