Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Fri Nov 19, 2004 2:36 pm
The main difference in changing tire sizes, is that by going to a smaller tire size, would not net any more faster ET's because the car is now going slower, than before with stock tires.
The problem wiht bigger tiers, is weight, and mostly wind resistance at higher speeds. Taller tires usually give you worse gas mileage. I have experimented on my Nissan truck. I started out with 225/70/15 and went to 225/60/15, and tried 235/75/15 tires. The best mileage was the smallest tires, even though I was running higher RPM's.
A lot of drag racers, use the higher rearends, to offset the taller slicks they run on the back of the car.
The ral problem comes in, when the slicks "Stand" up. You have seen the top fuel cars, where the tires grow asround 25%
