tire blowout, s13 wont start
kylekinnamon1989
Car: 90' Nissan 240sx SE/ SR20DET
1990 240sx body 1991 engine ka24de ....so my front left tire blew out and right under the fender there is a wiring harness. so the wiring harness ripped and i fixed the wires but now it wont start.. i can start it from a solenoid that is connect to the battery and starter (dont know why its there but it works) but it wont start from the ignition.. but when i turn they over one of the relays clicks.. the one that is under the airbox. dont know which one tho cuz the letters are faded. please help
S14Juggalo
Car: 95 240sx (S14)
Is it popping any fuses or anything when you try to start it with the ignition?
kylekinnamon1989
nope.. i check all of my fuses multiple time and they are all good.. also, when i went to work it started up from the ignition but when i left it wouldnt start from the ignition... it kinda works when it feels like it
S14Juggalo
Car: 95 240sx (S14)
WTF!?! Im at a lose for words other then its your actual ignition!
del82
If you're sure you've repaired the harness correctly (and no plugs have been yanked out due to it being hit by the tire) then the problem is unrelated. I'd go about it along the normal diagnostic routine instead of focusing on the part that got fixed.
