tire and wheel fitment
96Qowner
Car: 1996 Q45
The offset should be marked on the wheel, along with the width, etc.
Here's a tire/wheel fitment thread:
zerothread?id=223195
Workable offsets vary quite a bit, but you know these wheel/tire combos fit. Be sure to note that some are using spacers, which is not recommended without understanding their limitations.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
Thank you. You are quite the proverbial Fount of Knowledge. I appreciate your answers.
96Qowner
Car: 1996 Q45
You're welcome, but heheh, I'm just the Librarian. I remember these threads and know how to find them with Search.
Notice, Romeo has 20s. Also notice no one on that thread is running anything wider than 245s and 255s.
Haitian_King
Oh no! More numbers.
The 245 and 255, do these translate to low profile tires as well?
96Qowner
Car: 1996 Q45
Any profile, yes - width is width.
As long as the thread Title is so specific, I'll include these old threads for future searchers:
zerothread?id=224826
zerothread?id=221062
zerothread?id=219861
zerothread?id=199756
zerothread?id=181480
zerothread?id=171623
It looks like 9 inch and 275s are the limit without dealing with fender rolling.
Happy reading!
Haitian_King
Thanks a million!
96Qowner
Car: 1996 Q45
96Qowner wrote:Any profile, yes - width is width.
Need to clarify. There's one more factor - your tire and wheel total 26 inches in diameter. You have to stay close to that or it will drive your TCS and SLIP crazy, not to mention the speedo error.
Here's a calculator for diameter and profile (java applet):
http://www.miata.net/garage/tirecalc.html
OEM size is 215/65x15.
So, only certain profiles will be correct. 275/30x20 for instance are 26.5 inches tall. 255/30x20 are 26 inches exactly. Tires in a 25 profile 20 inch tire would require 305s for the right diameter. 35 profile will only fit in a skinny 215.
Check Tirerack for available tires in the size and profile (and load rating - at LEAST 95) you're thinking of.
http://www.tirerack.com/tires/index.jsp
