The Pitt wrote:So im a newb when it comes to overfenders and wheel offsets so i need a little help. i searched for a bit but there is so much information its hard to sort through what i really need to know. heres the deal i got a cheap set of 5zigen fn01r-c for my 89 hatch, rear 17x10 +12 and the front 17+9 +15 offset. what i really want to know is what size fenders, if any are needed at all, am i gonna need to fit the rims under it. also what size tires should i get, i want them to be slightly stretched but not too much. thanks in advance!
matt
you dont need overfenders for that size. Just roll your stock fenders flat.The Pitt wrote: rear 17x10 +12 and the front 17+9 +15 offset.
nonecrapanese wrote:does the car with the +20 offset have any wheel spacers ?
False information...... his +12 will sit IN 12mm more than yours. So like Adrian said, a flat rolled fender and a stretched tire should be nice and snug.ELEMENT692121 wrote:im
im running 19 by 10 on the rear 0 offset and i need about 15 mm to get the right clearance .. your plus 12 so that puts you at about 27 mm so a 30mm over quarter should cover you .. as far as the front im running an 18 by 8 0 offset and i have plent of room if your plus 15 on a 9 inch rim id say you still wont need much if anything at all .. just for refrence your tire size will make this vary a lil also .. im running a 225 front and a 265 rear ..
