greg_atlanta wrote:Flat spotting is worse on high performance tires with soft rubber, esp. summer tires. Also more likely on lower quality tires.
The real problem lies within the casing construction and material used in the casing, not so much the tread. Rayon, if I recall, is one material used in some UHP tires that is known to cause, in a sense, "flat spotting" from sitting idle.
Just like some of the bias-ply mud tires that must be run at speed to become "round" again... the same theory holds true with many car tires.
If you remember, in a recent post from Q45tech, the page he posted from Infiniti about balance procedure specified running the car at 70mph for 30mins(i think) then immediately checking balance. This would help eliminate such flat spotting. -Master of the obvious.
