I see in your sig that you have an s13 & s14. When removing the old ka harness from my s14 I got stuck at the same spot. I had to remove my glove box, and undo the bottom 2 nuts that hold in the blower motor to pull it back a bit. Since I already had discharged my a/c system to have my fabbed up lines made, I also removed the screws for the evaporator core and removed it too, to buy myself a bit more room down there.
I guess that you could re-pin each individual wire on the sr f4 dash plug since they look identical. I'm just going to solder my m63 plug in place of the f4 plug I think.
otterman wrote:I wont tell you sh** until you post up pics!
Come on bro, share the knowledge. I looked at the "how to post pics" tutorial, and it seems to be a different/old format, and I couldn't figure it out.
I'm also trying to find more wiring info on swapping an s14 sr into s14 kouki.
