Warped »
https://forums.nicoclub.com/warped-u5976.html
Sun May 07, 2006 5:47 pm
unless you get it from a sponser there really isn't much you can do.take off the oil pan and check and see if the pichup mas a scraping pattern in the pan,if so knock it out a bit or do the pickup mod.other than that you can ask for a compression test wich doesn't tell you alot for a motoer that has been sitting for 6 years.and a leak down test , good luck let me know what company is going to do that on a motor that has been stiiting to a couple of years and is going to give you honest answers
sorry for the mis-spellings im a little drunk
