tips on installing headunit/removing stocker
ECMgarrett
Car: 2003 Nissan Pathfinder - 1993 Toyota MR2 Turbo - 1999 Buell S3 (drag) - 2008 Buell 1125R (street)
03 pathfinderjust bought a pioneer avh-p4000DVD, installing in a couple days when it arrives.
curious what pieces need to be removed to get stock unit out and best way to do so without cracking anything.any tips or tricks?
any help is GREATLY appreciated
thanks guys!
bmlawless
Car: 1999 Infinity QX4
They are super easy to remove. This link will take you The Install Doctor's page for pathfinders. The process is the same for the QX4.
http://www.installdr.com/Insta....html
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
if its the same as my 99 qx4 then theres 2 screws hidden at the bottom of the whole trim piece, then you just rip taht out and 4 screws around the head unit and u all set
ECMgarrett
im installing a doubleDIN unit, anything special for that?this will by my first time installing one of them
thanks for link, reading that now
ECMgarrett
ok, the instructions on that page dont pertain to 03 pathfinder, the two lower screws it mentions arent there etc
any other help???
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
I think it's the same as my 01.
1. Pry out the Air Vents.2. Disconnect power cable to clock.3. Remove the 2 screws on the trim right below the vents.4. Pull out the trim piece a little and disconnect climate control, hazard lights, cig lighter and ashtray light connectors and you should be good to remove the whole trim piece.
Good luck!
Billy
ECMgarrett
Empty V wrote:I think it's the same as my 01.
Good luck!
Billy
thanks brolooks like we have similar headunits, double din pioneer dvd unitany more pics of your audio setup?I looked on your thread, but would like pics of your dash etc
i'll mess with it tomorrow and see if i can easily pop those vents out etc, I think it'll be here tomorrow
Qxxx4
2012 Ford Mustang
ive got a double din pioneer....regular style not screen. It was extremely easy to install. the brackets mounted on the stock deck bolt directly to the pioneer and fit PERFECTLY and theres a trim piece for around it, really easy install thanks to pioneer
87lxstang
Car: 2001 Infiniti QX4, 1987 LX Mustang, 1992 GT Mustang
I know my 01 Qx4 has an "irregular" shape Bose unit in it. I read elsewhere online about people modifying single-din kits to work, so I'm about to attempt the same. I'm not sure if the Pathys are the same or not...
