jimmyzzer »
https://forums.nicoclub.com/jimmyzzer-u79387.html
Thu May 29, 2008 12:12 pm
WD21 info for Pathfinder from 87-95: Main problems.
Frame rust. Even on non-offroaded Pathys, the frame can rust out quite badly from the inside out, particularly in the rear over the wheels and above the gas tank. Tap on your frame with a small hammer or poke it with a screwdriver to see if you have more holes than you should. ALWAYS inspect any WD21 Pathfinder you wish to purchase before buying it in this regard. Other rust-prone areas are directly under the gas pedal on the floor (the catalytic converter is there and sometimes a leak can shoot superhot exhaust at the floor, which rusts it out badly), under the back seats on the floor (poor seam sealing on Nissan's part) and at the tension rod frame mounts up front. Tension rods are the short bars that go between the lower control arm and the frame in the front suspension. The tension rod mounts have a tendency to waller out and/or rust out, which can result in a broken tension rod and the need to re-weld some steel back into the mounts to fix the problem. Tension rods are also called compression rods or strut rods. I recommend using polyurethane bushings to replace stock rubber tension rod bushings whenever possible.
The stock transmission cooler for automatic transmissions needs replacement! On automatic transmission-equipped Pathfinders: failure of planetary gear set and loss of reverse or forward gears: the stock transmission cooler on WD21's is a far cry from adequate. The stock cooler clogs up over time and chokes line pressure to the transmission, which overheats it, reduces lubrication and RUINS the transmission. The stock cooler is located inside the radiator, which has line inlets at the bottom of the rad.
If you are reading this, have an auto 87-95 Pathy and haven't done so yet, GET AN EXTERNAL TRANSMISSION COOLER.
was posted by 88pathoffroad in the pathfinder faq forum
