RB20DETodd wrote:
I think the rb25 gets the extra power from the .5 displacement, and 240hp on a stock rb20 with a rb25 turbo? at what 14 psi lol
From what I've read (and hopefully will find out in a couple weeks), the Rb25 turbo is a very good upgrade for the Rb20 on a budget.
240hp has been verified with supporting mods. What's so great about that you might ask... It pretty much maxes out the stock injectors.
I've been starting to think of RB20 mods in terms of stages. Here's my basic outline.
Stage 1 = Fuel pump + Breathing (Pod filter, catback exhaust, test pipe or straight pipe, FMIC, blow off valve, etc.) Then install the Rb25 turbo. This should get you to 240whp with proper timing. Stock internals, stock fuel system (other than pump), and stock ECU.
Anything more than 240hp and the 270cc injectors are a little iffy. This is a great goal for a budget since the next stage of mods get a lot more expensive.
Stage 2 = Upgrade fuel, airflow, and engine management. To get over 240hp, you will need more fuel.. Recommended upgrade level would be 440cc GTR injectors or Supra injectors or even some 550cc aftermarket injectors. You will need to upgrade your MAF at this point as well. The common mods are Z32 or Q45 to help read enough airflow. You will need to run some sort of engine management now as well. From the basic SAFC2 to chips to emanage to full standalone, etc... you will need to be able to control air/fuel maps for the car to run properly with more fuel. Now that you got those, you can install a bigger better turbo. GT30's, t3/t04e, etc... There are a lot of options. Another upgrade to help would be better cams. You should be able to get at least 350hp and perhaps up to 400hp. Still on stock internals. You might even consider alchohal injection. One RB20 in the states hit 495 whp with alcy. and stock internals.
Stage 3 = Internals and others... To explore the higher bounds of the RB20, it is recommended to rebuild the engine with forged internals. You may choose to increase the displacement to 2.2, 2.3, or 2.4 liters. You may upgrade cams now as well.
