steve_c »
https://forums.nicoclub.com/steve-c-u163301.html
Wed Nov 19, 2014 3:32 pm
You need this:
Lisle 24610 Spill-Free Funnel
About $35.00 on Amazon. It is basically a large funnel with airtight adapters allowing you to keep the fluid level fill point above everything else while system is burping.
(You have the right idea when you alluded to raising the front end up high to keep the radiator fill at the highest point of the cooling system.....this funnel does that for you keeping the car on level ground).
Keep the heater on while doing this so coolant flows through the core.
Burping this system is a PITA, only other way to to it better than this is pnuematic/vacuum bleeding.
SVARDS posting is basically how I do it, using the lisle funnel kit. I cannot express enough how careful you need to be while working with this stuff. Follow all safety procedures. I had a recall for the fan controller on my 2006 M years ago. The idiot tech let my car get to operating temps, then shut it down when the fan did not come on at specified temps. He then made 2 mistakes back to back.
The jerk opened up the system hot, that was steam/antifreeze shower #1.
He then poured anti freeze in, started the car, continued to add, and when the air pockets locked up system, he got another anti freeze/steam shower. I cannot believe how fortunate he was that he was not scaulded....not once, but twice!
