how long should it take for all little bubbles to leave the window because like i said before ive had it for about 2 months and there is still some bubbles left i might have to go back and have them redo atleast 4 windows, lifetime guarentee, and the armor all wipes have no ammonia so there safe.proxim2020 wrote:An alcohol based window cleaner and a soft cloth will be fine. Mild soap also works. Never use a cleaner with ammonia in it since it will eventually destroy the film. Regular windex has ammonia in it. There's a Windex with no Ammonia. Armor All wipes don't have ammonia, but check the packaging to be sure.
i live in florida its been hot every day for the past month.... well ima wait it out another month and see how it goes ps. aimClipsed wrote:If it has been cold, wait about another month or two before getting them redone, heat will either spead the bubbles, or take them away, so keep an eye on that, I am having my tint redone due to some bubbles, and the way they cut the tint was bad. Use a microfiber cloth with "Invisible Glass" window cleaner, works great, and wont mess up your tint.
two and a half weeks is awfully quick it that kind of weather. But 2 months is not necessarily long, it all depends on the type of tint used, some tints can take up to 3 months to set properly in good conditions, there are many variables. Lifetime warranty, means you can wait however long you would like to have it redone, but I would suggest you ask what the warranty covers as all tinters are different in their lifetime warranties.Jemdawg wrote:Hmm, two months sounds like a long time for there to still be bubbles. Mine went away completely after about two and a half weeks in 30ish degree weather. If it has been warm down there, there should be no reason for you to still have bubbles. I'd look into getting them redone, my guess is that it was a really humid day when they were done, and a lot of moisture was caught under the film.
HaHa I do too! Comes in handy all the time!Nismo V wrote:True clipsed, climate does affect the curing time on tint...
Invisible Glass way to go
I keep a can in the V...
