240sxproblems wrote:Well before I put the timing chain on I turned the engine several times by hand and was not sure if it was at top dead center or not when I installed the timing chain to the idle pulley.
Since you aren't sure, I'm gonna go ahead and guess you didn't install the timing chain correctly, you probably also didn't line up the distributor correctly.
The best reference would be the FSM, which you can find a link to by searching on these forums. In there, there is a detailed guide on installing the timing chain.
You may have lined up the top mark, but you have to make sure the mark on the crank is lined up, too - otherwise it is useless.
Also, did you set tdc before you started removing stuff? If you aren't sure, then you probably have to start all over (relatively).
It's a daunting task, but you need to at least make sure you know the correct steps or you can easily blow your headgasket (or other things) again really soon.
