Not_a_sr »
https://forums.nicoclub.com/not-a-sr-u23501.html
Mon May 09, 2005 8:21 pm
well, my mechanical timming is good. darrell called me gave me some advice, its been suggested my exhaust cam is off a tooth could be but ive checked it numerous times after running the motor i really dread taking the belt off to redo it. we buttoned it all back up checked the timming it was off around 25-30deg advanced, well the problem may have somthing to do with me not running a AAC valve anymore and the TPS needing adjusting to compensate, we worked on that, got it to 15BTDC, but my CAS is fully clockwise. the motor was running pretty good, couple misses here and there, would rev out fine, went to take it out of the garage and it would buck like crazy.
check my ECU only code i get it 13. coolant temp sensor, my temp gauge wasnt working either so im assuming i need to change the temp sensors, the plugs, and then get that timming issue fixed permanately soon as we figure out what it is..
by the way ive completely done away with the FCID,AAC, and the Air regulator.
