timming chain question
fresh240
Car: 1991 240sx
i got a ticking noise comiing from my timming chain. could it be the chain that is worn out or could it also be the cams.
plane16j
Car: 91 nissan 240sx
sounds like chain guards are worn out
bk00maxse
Car: 2000 maxima se/2003 infiniti q45
i got the same problem on my 2000 max that crap is annoying its better you change your water pump timing chain and the guards this will solve your problem it sounds like the engine is knocking and its loud sometimes
dickie
Car: Killer Turtle
d!ck wrote:
Hey, just an FYI on the timing chain guide removal:
I spoke to a couple Nissan techs (one at the dealership and one that had been working for Nissan for 20+ years and now runs his own shop) prior to doing mine, and they recommended that i NOT remove the side chain guide, and that if i was replacing the chain and tensioners anyways, there was no reason to remove the top guide either.
the deal according to them is: as the chains and tensioners wear, they create just enough slack in the chain that you hear the "ticking" against the upper guide. the components probably have a lot of life left in them after that occurs, which is why Nissan decided to inform ka24de owners about the optional removal.
the procedure, although stated otherwise elsewhere, should NOT include removing anything other than the upper guide. PERIOD.
also, i still have my upper guide after replacing the chain components and have experienced no ticking after over 10,000 miles of use.
plane16j
hey thanks for the clarification. it was really informative
fresh240
Car: 1991 240sx
i took off the top chain guide and the top ticking/scratching went away. theres still some coming from underneath. how many chain guides are there.
dickie
Car: Killer Turtle
there is a side guide and an upper guide. if you remove the side one, there is a chance your chain could be just slack enough to jump the sprocket and cause your valves to hit your pistons ruining them.
replace your chain and tensioners.
fresh240
Car: 1991 240sx
is there a way to tight the tensioner. if so would that help
dickie
Car: Killer Turtle
if it's stopped working correctly, replacement is your only option.
bk00maxse
have a quick question my timing chain guards tensioners and water pump needs to be replaced but there is a weird problem when i am driving and the temperature control is on the heat side the heat is not on heat comes through the vent slowly and its kinda weird and when i switch to ac the same thing happens what could be the solution to this? will changing the timing chain,guards and the tensionerssolove this problem ?someone answer please this is really freaking annoying i wanna fix this and also the car gets no heat at all i get a lil ac but not like the way it was last summer what could be the problem behind all this
dickie
Car: Killer Turtle
if you have your climate control set on "fresh" ie not recirc, air will pass into the cabin.
if your car is not overheating, you dont have a problem thats affecting the water pump.
bk00maxse
the car overheats every once in a while and there is a knock coming from where the timing chain is located nissan told me to change the water pump and timing chain antifreeze backs up into the overflow tank everytime i drive
Kraffty
Car: '95 240SX SE
What all is required to remove the top chain guide? I'm new to the forum and just starting to tune my ka24de. I have that same knocking noise, but only at idle speeds. As soon as I touch the gas, it goes away. Could this be just the top chain hitting that top guide? I don't want to take something off that will cause my engine to fail.
