I am changing the timing belt and broke the arm on the tensioner which is only used to install a bolt and prevent it from
moving during shipping and part removal. I used a clamp to get the tensioner off. can I reuse the tensioner with out this arm?
Thanks I assumed that just needed the warm fuzzy, it is only a couple of years old.swimshark wrote:you can drive without that piece, its just going to be a pain to get the tensioner to go back in so you can get the belt on.
