timming again
tony/ka24de
I've done timming before but forgot what rpm the car should be at and what the marking are on the crank. I think it is from 20 to -5 from right to left. And should the motor be under load or does it even matter.
HybridOne
Car: swaps
850 rpms
you are right on the marks, but it is 20 degrees before tdc on the right and 5 degrees after tdc on the left.
so maybe thats -20 to +5...i dunno how you write it.
there is also an elaborate formula to getting the ECU into timing mode...and i don't know it positivley so i'm not going to give you half *** instructions. though i will say it involves unpluging the TPS.
