Timing Woes(ka24de)
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
I set my timing to aprox. 17-18 deg btdc, it feels great but in about 2-3 mins it looses a little power up top and i recheck the timing to find its dialed back to about 22 btdc... Is my car changing the timing for some reason? How does it do this? and how can i stop it? It sputters @ full throttle under load with timing like this ...
uno
disconnect the tps when you set the timing
E Dogg
Car: 1997 M3 sedan
thanks that helped but its still shifting a bit... Knock sensor picking up my header mabye?
uno
yeah or knock sensor is going bad possibly too
E Dogg
Car: 1997 M3 sedan
It is throwing a knock code but I know it isnt really knocking. It's actually missing b/c the retarted timing. Can I run w/o the sensor to see if thats the issue? I know some cars go into limp mode without it...
uno
i think ours go into limp mode without it....they aren't cheap either, like 100 bux i think or more...
E Dogg
Car: 1997 M3 sedan
ewwwmabbe a resistor that tricks ecu int thinking things are ok? hehe
uno
haha good idea until something really does go wrong haha
E Dogg
Car: 1997 M3 sedan
whatever 100 for sensor how much is entire ka 2-300...?
uno
haha good point....
E Dogg
Car: 1997 M3 sedan
reason for sr too hehe
