onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Jan 10, 2006 12:59 pm
no, i don't think chain guides would have anything to do with your situation. The timing guides were probably removed bcs they pose more of a problem later than help.
What is your timing set at right now? and are you sure you are looking @ the timing mark correctly (perpendicular to the crank pulley center, not straight down) - I only ask this because I used to look at it at the wrong angle.
If that is all done, then it's not your timing, it's something else. No engine check lights? I would check out the idling problem threads if I were you (if that is the only problem you are having).
