Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed May 14, 2008 5:22 am
I suggest removing the oil pump drive spacer off the nose of the crank. It makes installation easier of the front cover. Then you can put the spacer back in afterwards.
If you can't get it off the crank, then do what was suggested. Slide the top on first and then swing the lower end on. It's a bit tighter, but it's doable.
I also suggest getting the two top bolts started before you install the front bolts. You'll never get them started if you tighten all the front cover bolts first.
