toki »
https://forums.nicoclub.com/toki-u4152.html
Sun Jan 23, 2005 11:00 pm
All this talk of 16ish degrees timing at WOT has got me thinking, I really have no idea where my timing is at right now on my SOHC at WOT, but stock timing is 15* not 20 like on the DOHC, so i'm not sure how the ECU adjusts for timing in the map. Does anyone know if the base timing is just lower, and it has a more aggressive timing progression in the top end, or if it it's just step for step less timing? The motors are almost the same except for some deck height and head displacement, I don't see how timing should be so much different, static compression is lower on the SOHC also.
With stock timing at 15* do you think retard will still be needed once I get past 7 pounds or so? My timing was somewhere around 18* I think when it was NA, and I had no problems to speak of even on 87.
