timing
JohnM312
Car: cars, juggling, ladies
how do I adjust the timing in my car?( s14 240)
JJ240
Car: 95 white 240
Ignition or Valve timing.
JohnM312
sorry for not clarifying that earlier, valve timing.:ylsuper
JJ240
Car: 95 white 240
np. To adjust valve timing you will need a set of adjustible cam gears. For best results you will also want to know what the timing should be. When you purchase aftermarket cams you will often have optimal timing listed on info that comes with them. If you are using stock cams or didnt get that information you may have alot of dyno time needed to adjust them and test to get best results.
