Grab a timing gun, hookup the trigger wire to the #1 cyl. With the engine off slightly loosen the CAS bolts, start engine, point timing light towards the crank balancer/pulley mark and tap the CAS until you are at FSM specs. I believe 15degrees +/- 2.73EB wrote:So how do you set the timing? I can't find it in the FSM online manual. Do you just put the #1 cyl to TDC and stab the CAS in? Thanks
Jeff
